View Full Version : Bizhub c450 - flashing start button
bagchi
08-25-2010, 04:26 AM
I Recently moved this unit Bizhub C450 to another office and now all that happens is the start button flashes and will the unit will not make copies or prints-- any suggestions to try ?? Thanks :confused:
Stirton.M
08-25-2010, 11:11 AM
Call a local service tech to troubleshoot this. Likely you did something wrong like unplugged something when the main power was still enabled.
bagchi
08-25-2010, 01:25 PM
thanks, i am local the local service tech that was called and i am looking for advice on how to trouble shoot this----
HORSE
08-25-2010, 01:32 PM
Nice!! RTFSM
buster68
08-25-2010, 02:28 PM
your PWB-SIF board is dead...happens all the time when options are disconnected before machine is properly shut down and unplugged from the outlet.
emujo
08-25-2010, 02:33 PM
Since the MFP was moved, the fax board (if installed) may have backed out of its slot. BTW, if you are a KM tech you should be able to access all this info on the knowledge base...might save you some time in the future. Emujo
B0265
03-23-2011, 11:28 AM
We have the same problem on a C253, also after the customer moved the machine to a new loctaion.
So far we have checked the connection to the total counter and changed MFP Controller PWB and Printer Controller PWB.
Will try Power Supply next, or does anyone have another suggestion?
