View Full Version : Error Code minolta cf 3102
beano
08-26-2010, 12:56 AM
getting coo46 try to figure out the fan that is bad and where its located
RRodgers
08-26-2010, 01:16 AM
Ohh... I think that's the one that cools the fuser. It's been a while since I worked on that box. Umm... try just reseting the code. Open the front door and just below the blue handle (to the right of the black toner) in the SQUARE HOLE (not the round one) hit the reset button with a ball point pin and see if it will reset and fire back up for you.
beano
08-26-2010, 01:29 AM
i did it keeps comming back
RRodgers
08-26-2010, 01:34 AM
Did you double check to make sure the filter (the one that use replaces with each black toner) is not all clogged up?
beano
08-26-2010, 02:33 AM
yes
RRodgers
08-26-2010, 02:35 AM
yeah, looks like you got a bad fan then.
