View Full Version : Bizhub C10
chuckt528
08-26-2010, 05:11 PM
Hope someone's seen this. Doc feed will not drop pick up roller. Clutches and rollers seem good. If we press on bracket, it will usually fall. Thanks in advance.
mo0651
08-26-2010, 11:01 PM
had a couple of di1610 BH160. doing the same thing. Seems the separation pad has a lot to do with it. We replaced the pad and the friction started it working.
mansart
08-27-2010, 12:56 AM
this is correct, I would check the sep pad, make sure it is in contact with the feed roller. It is possble for the pad to get pushed down too far and have it lock into this lower position. when in this position the PU roller will not drop
chuckt528
08-27-2010, 03:14 PM
Thanks guys, you were dead nuts right!......ever feel like a moron? 5966
mo0651
08-27-2010, 04:53 PM
Are you kiddin. Took three days and three guys to figure out what makes that POS go. LOL
