View Full Version : 7228 scan to box erase time setting
kingarthur
09-01-2010, 04:22 PM
Hi
I've got a customer with a 7228 on which they are scanning to box, it is set to erase anything in the box after 1 day, i cant seem to find out how to change this setting, i've set up a new box account on the m/c & it doesn't give me an option to set up the erase time.... it's probably something simple (apart from me that is ) but can anybody enlighten me
cheers
jma676
09-11-2010, 09:57 PM
Ok, Thank you! and maybe you need post this thread here:
Connectivity (http://www.copytechnet.com/forums/connectivity/)
173545
09-27-2010, 08:46 PM
Description
How to set the ScanAutoDelete time of document stored to a box.
Solution
To set the ScanAutoDelete time, perform the following:
1. Press the Help Key and then select KEYOPE mode.
2. Select SYSTEM INITIAL.
3. Select DOCUMENT FOLDER.
4. Select SYSTEM BOX OPTIONS.
5. Select OPTION SETTINGS.
6. Press the Edit icon to select the desired time, None, 12hrs, 1 day, 2 days, 3 days, 4 days, 5 days, 6 days, 7 days or 30 days and press OK.
7. Press RETURN 3 times.
