Greetings,
I am the systems administrator for a publishing company. We may end up purchasing/leasing a Bizhub 363 to eliminate an old Muratec fax, and two Xerox Phaser 4500/3500 printers.
I have some technical questions for you:
Have any of you had problems with the JS-505 job separator attachment? We need two output trays:
1) for all print jobs and 2) for printed invoices. As it is now, people end up picking up printed invoices or faxed invoices by mistake, and as a result, orders do not get pulled. Ideally, we would set it up so that all print jobs go to one tray be default, and invoices print to the second tray. We simply do not need the advanced finishers.
I heard that print jobs are interrupted while faxes are being received? Is this correct? My concern is that occasionally we may have long faxes where say someone is faxing a long list of manuscript corrections to us, and it would be nice if print jobs could continue to be printed while faxes come in.
If we switch to faxes being stored digitally in a mailbox on the hard drive, would this eliminate the problem of print jobs being interrupted by incoming faxes?
We are running all Mac (10.4.11-10.6.4). Has anyone encountered any postscript errors printing from PDF or Adobe apps (particularly InDesign, Illustrator, Photoshop CS3).
Anyone know of a workaround to using the network fax option from a Mac?
Thanks in advance,
Tyler
Thanks in advance,
Tyler
