View Full Version : Miscellaneous Konica 7155 Memory error??
technician
09-08-2010, 05:15 AM
:) Hello Every one :)
I am facing a problem in konica 7155/7165. Machine connected with lpt cable ( for printer).
And had install konica IP-511 PS printer driver.
But copier is not working during printing.
some times copier is making some print.
But the speed is very slow.
Test print is made easily.
I has checked the LPT cable and printer board. both are working.
please give some suggestion.
Is the problem of virtual ramm??
how to solve it?? or
is the problem of printer driver??
please give me detail answer. i am waiting.......
ni311
09-08-2010, 03:19 PM
Try to install a different version of the driver, try to print from another application and/or try to install the same driver on a different computer.
mrwho
09-08-2010, 04:47 PM
I'd also advise you to use network cable for printing instead of LPT - for troubleshooting the issue but also because network printing is faster than using the parallel port. If you don't have a network switch you can buy a crossover cable to connect the machine directly to your PC, although most modern computers accept even regular cables because they auto-select the correct connection.
Konica_jr
09-08-2010, 05:15 PM
.pdf files are very slow with the ip511, you can try to change your lpt1 communication settings to ecp+epp or ecp only, it will be better to connect it on your network,
regards,
