View Full Version : Error Code C 5008 Bizhub 750
Scijohn23
09-13-2010, 06:07 PM
Hello, Not that familiar with Konica/Minolta, Can anyone tell me what this code relates too. it displays C-5008 code.
Thanks in advance,
John
Scijohn23
09-20-2010, 06:57 PM
hey guys, I could still use some help with this, if anyone knows the solution please let me know
John
mrwho
09-20-2010, 07:01 PM
I never got that, so I only know what comes in the service manual. If you don't have it, here's what it states:
C5008 - ADU drive serial input abnormality
The serial data is not received from the ADU drive board (ADUDB) with ID=0 within a specified period of time after ACK when the power switch (SW2) is ON.
As per the manual, you should replace the ADU drive board ADUDB.
Scijohn23
09-20-2010, 07:15 PM
Thank you, Mr. who
Scijohn23
09-20-2010, 07:17 PM
Thank you, mrwho, I am trying it now, I will let you know the outcome
Scijohn23
09-20-2010, 07:19 PM
Internet explorer 9 sucks, sorry for the double post
mrwho
09-20-2010, 08:00 PM
It does suck indeed. Go for Firefox, Chrome or Opera - any one of these is better than IE.
Scijohn23
09-23-2010, 05:08 PM
I changed the adu board with another one and I am still getting the same error code. Maybe I should change the whole duplex unit?
mrwho
09-23-2010, 06:14 PM
I doubt it. It seems like you've got some wiring problem - maybe a pinched or broken wire or a bad connector. I'd check every connector on the ADU board first for bent pins or broken wires and then, if you don't find anything, also on the other boards.
Good luck - that one looks like it's going to be a blast!
DocuJustin
05-19-2016, 05:43 PM
I know this is an old post but... hopefully it will help someone.
We had a 601 doing this. We ended up reseating all connections on the main board and it fixed our problem. I would try that first and then maybe replace wiring harness 2nd.
