View Full Version : Coin- Operated hook-up
BlueBlazer
09-15-2010, 03:59 PM
Hey hey, I was wondering if someone could help walk me through how to setup a coin-op(or for that matter anything key-counter operated). On a cs pro 3000, or Bizhub 350.
What I do know is that there is a 12v in and out and a 5v switch, but I have no idea how to turn them on once they are hooked up. Any help would greatly appreciated.
The forums have been a great help to me so far but I havn't been able to find anything anywhere on how this is done.
pepper38_cnd
09-21-2010, 11:55 AM
What type of Coin Op are you trying to Install? All you have at the key counter plug is an enable and a pulse ( count ) and that is all you need. I have installed many XCP Coin Boxes from ATI (http://coin-box.com/index.cfm)with no issues. There are some soft switches that you have to set and some programming on the Coin Box itself to match the timing and vending costs. Open your service manual and search the word " vend " you should find all the info you need to set the copier, your Coin Op supplier should help you with the rest..
oldschool
09-21-2010, 03:10 PM
As far as the way Jamex (http://kmbs.konicaminolta.us/content/products/models/jamex.html) (my company) vends those copiers, It is through the key counter. All the instructions are in the copier manual. One thing to note though.; Some Konica Minolta models will disable the duplex option whenever the key counter option is turned on. I'd double check with Konica Minolta Tech Support to find out what (if any) features are not available in key counter mode.
