View Full Version : Error Code Konica c500 SC45-09
jzheld
09-15-2010, 05:15 PM
Any idea how to get rid of it, original got sc45-20, 45-09 appeared when I did auto color adj in 36 mode.
Any suggestions?
jma676
09-15-2010, 05:43 PM
Konica Minolta Bizhub Pro C500 Error SC-F4520 - F4509
Description: C45-20 occurs
Cause:Abnormal termination of color registration control.
1. Normal registration mark is not made on the transfer belt, The sensor can not read it because registration mark is not made correctly on the transfer belt.
Defective parts:(Transfer belt, Drum, Developer, Developing Unit,etc).
2. Defective color registration sensor.
3. Defective printer control board.
4. Defective writing unit.
Description: C45-09 occurs
Cause: When the laser correction motor /Cyan (M9) was ON, laser correction HP sensor /Cyan (PS7) was turned OFF.
Relevat Parts:
*Printer control board (PRCB)
*Laser correction motor /Cyan (M9)
*Laser correction HP sensor /Cyan (PS7)
You are creating serious problems with this. Be careful or contact a technician.
jzheld
09-15-2010, 06:33 PM
Thanks for your help, trying not to create any problem, I got the machine basically for free, it been in terrible conditions, already change a lot on it
jma676
09-15-2010, 08:14 PM
Ok, I understand, then tell me and went out.
You are Canadian?.
No Problem.
jzheld
09-15-2010, 09:33 PM
Thank a lot man for you help, it worked, it prints not a really good quality but prints, so that is a good start, I think I will be able to fix the rest, at least there is no errors. I live in Toronto, but hasn't been born here
