View Full Version : uses toner bizhub C450 to Maximent
djsayan
09-16-2010, 12:45 AM
hello everybody I have a bizhub C450 every time a color is almost empty I get a message that I need to change the color toner has every faith that I let the machine prints shows how the message until the cartridge is empty but not before
and thank you
Stirton.M
09-16-2010, 02:43 AM
Eventually the machine will physically lock up when a low enough toner condition is detected by the machine. You can leave the toner bottle in the machine until this happens, then simply pull the bottle and replace with a new one and the machine will resume normally. In some cases, you can lightly tap the bottle to loosen any toner stuck to the sides of the container, but generally the bottle will be empty when the machine says it is.
djsayan
09-16-2010, 11:58 AM
hello. what 'm saying I know, but I think there's an option or you can change the message toner is almost empty with the message stop or non stop so the machine does not stop or not or what blocks
djsayan
09-16-2010, 11:07 PM
there is no solution for this problem or any other idea
djsayan
09-17-2010, 05:06 PM
up up up up plz
