View Full Version : Error Code bizhub pro c6500 c-4724, c-4723 c-4725 c-4722 codes
OKcopyguy
09-16-2010, 01:33 AM
Started out with c-4716 code. Moved suspect laser but the problem did not move. Tried different Image Control board, Printer Control Board and interface board. No help. After putting everything back together we started getting random c-47xx codes immediatly after copier starts warmup. Can't seem to get any of the polygon motors to run in I/O mode.
jma676
09-16-2010, 01:41 AM
tries to read the field manual, the troubleshooting item.
I'm going, maybe now is Stirton.M or Horse, they like to spend hours here talking.
See Later.
Good Luck.
jma676
09-16-2010, 01:57 AM
-------------------------OK Five Munite.----------------------------------
Konica Minolta Bizhub Pro C6500 SC -4722/4723/4724/4725.
Cause:Connection Abnormality Between Index Board/Y,/M,/C,/K (INDEXB/Y,/M,/C,/K) or the laser Drive Board Y,/M,/C,/K (LASDB/Y,/M,/C,/K) and the image process Board (IPB)
Relevant Parts: Image Prossesing (IPB), Write Unit /Y/C/M/K.
Tal Parece que algo quedo mal conectado Pay, trata de revisar que carajo quedo desconectado.
Stirton.M
09-16-2010, 02:50 AM
According to the TSB/TAD
the only code found there was the 4725
CAUSE: DCPS 1 has failed.
SOLUTION: Replace DCPS 1 (p\n A03UM40201).
RAI
03-01-2022, 04:17 PM
You have to love general error codes. But you are quite correct Stirton. Looking at the source power is the answer.
I know this thread is old but still relevant.
Synthohol
03-01-2022, 06:50 PM
He probably figured that out 12 years ago when he posted ;)
