View Full Version : DI2510....USB
connecticcut
09-18-2010, 12:14 PM
My computer don't see (connexion) the copier.I have to install driver but it don't print.
Maybe,i forget to modify parameters on the machine DI2510.
What's solution?
thanks
Emjay
09-19-2010, 01:45 PM
Not sure I fully understand your question. This model does not have USB . Can you be a bit more specific about how the copier is connected and what you are trying to achieve?
connecticcut
09-19-2010, 02:32 PM
you have 2 connectors = RJ45 (network) and USB.
the customer hasn't network and i use the second connector but i don't arrive to print.
connecticcut
09-19-2010, 05:54 PM
it's ok now.Problem with network card (to exchange)
aleksander
09-20-2010, 10:22 AM
you are using optional NC4 & Pi3505e. Your problem is in your NC4.
connecticcut
09-23-2010, 12:46 AM
thanks
i don't find driver for vista (i have pcl and not ps card).It's necessary to replace pcl for PS card?
connecticcut
09-26-2010, 03:33 PM
i have to install PS card.It's ok for XP but it don't print with vista.
RRodgers
09-26-2010, 06:50 PM
just set it up to use an HP LazerJet 4 driver and it will print. You won't get much else out of it, but it will print.
