I'm having trouble setting up new people with one touch for scanning to FTP using Bizhub Di 2510. Screen looks like below in PageScope Network. When I try to scan to Brian I get the Error Code ED09C6.
ED09C6 The LAN cable is not connected, or the destination address is incorrect. Check that the LAN cable is correctly connected. Also, check that the settings for the FTP server address, port number, and proxy server are correctly specified.
Older ones set up by someone else no longer with the company work. What am I missing?![Frown](http://www.copytechnet.com/forums/images/smilies/frown.png)
TX: PC(FTP Client)
Destination Name: Brian
Destination Address: 10.0.0.4
Port Number: 21001 (1-65535)
File Type: PDF
Coding Method: MMR
TX: PC(FTP Client)
File Type: PDF
Coding Method: MMR
