View Full Version : Bizhub 6500 printing off square
Scottyj
10-06-2010, 10:10 AM
I have a problem with our 6500 printing 'off square'.
Printing on A3 the long edge of the sheet is square, while the short edge is off square by 2mm at both ends of the sheet. The problem is the same when I copy or print from creo.
ineo+6501
10-06-2010, 02:45 PM
Are you familiar with carrying out the adjustments at the bottom of the machine tab?
Scottyj
10-06-2010, 07:48 PM
Is this section in reference to the area containing FD-mag ect
ineo+6501
10-07-2010, 08:27 AM
Yes
Scottyj
10-07-2010, 09:20 AM
Yes, I am aware of this section but have never adjusted anything yet
ineo+6501
10-07-2010, 10:00 AM
From the service manual. You need a 30cm steel rule to carry out this adjustment properly. You may also have to adjust the CD Skew.
Do you not have a service contract on this machine? Where in Morpeth are you?
Field Service Ver.1.0 Jul. 2008
9.3.3 FD-Mag. Adjustment (Printer Adjustment)
Adjust the magnification in sub-scanning direction.
This adjustment changes the speed of the polygon motor and adjusts the image magnification.
Note
• There are the following two methods to adjust the magnification of the printer in sub-scanning direction.
(1)FD-Mag. Adjustment (Printer Adjustment)
Perform this adjustment when the magnification in sub-scanning direction has changed because of the worn
registration roller or paper shrinkage by heat.
(2)Belt Line Speed Adj. (Printer Adjustment)
Perform this adjustment under the conditions not mentioned above.
• Magnification adjustment on back side in sub-scanning direction is not reflected to the image in default. WHEN
ADJUSTING the magnification on back side, enter "User Setting - Common Setting" and turn the "Side 2 Lens
Adjustment mode" [On]. However, since the polygon motor speed is switched for back side, the print speed is
reduced up to 3/4.
A. Procedure
1. "Service Mode Menu screen"
Press [01 Machine Adjustment].
2. "Machine Adjustment Menu screen"
Press [01 Printer Adjustment].
3. "Printer Adjustment Menu screen"
Press [03 FD-Mag. Adjustment].
4. "FD-Mag. Adjustment screen"
Select the item you want to adjust, and press [COPY].
This adjustment can be performed for both sides at a time (all trays) or for back side (each tray).
5. "Copy screen"
Select A3 or 11 X 17 paper and press Start key to output the test pattern (No. 16).
6. Check the magnification in sub-scanning direction.
Standard value: 0.5% or less (when in life-size)
205.7 ± 1 mm or less
7. When the value is not within the standard value, press [SERVICE].
8. "FD-Mag. Adjustment screen"
Setting range • Printer FD-Mag. (both sides at a time): -100 (shorter) to +100 (longer)
• Other than the above: -80 (shorter) to +20 (longer)
1 step = 0.01%
9. Enter a value through the numeric buttons and press [<<SET].
10. Repeat steps 4 to 9 until the standard value can be obtained.
57gaf3c003na
205.7 1
9. SERVICE MODE
150
bizhub PRO C6501
/C6501P/C5501
9.3.4 CD-Mag. Adjustment (Printer Adjustment)
Adjust the magnification in main scanning direction.
This adjustment changes the magnification in image processing prior to the laser exposure.
A. Procedure
Press [04 CD-Mag. Adjustment].
4. "CD-Mag. Adjustment screen"
5. "Copy screen"
6. Check the magnification in main scanning direction.
Standard value: ± 0.5% or less (when in life-size)
190 ± 1 mm or less
Setting range: -100 (shorter) to +100 (longer) 1 step = 0.01%
