tmaze01
10-07-2010, 08:35 AM
hi, i have a di 2510f i had to do an "all clear" in tech rep mode(warm reset)machine would not show warming up or ready to copy status also it does not show on the display "replace toner " when toner is empty so, copier continued to copy /depleting the developer
after replacing the developer and running the f-8 it copies fine /but i cant print to it like i use to (the red led on the back next to the usb is on ) even if the network cable is plugged in(cat 5). and it still doesnt sense toner /in fact i can remove the entire bottle and close the front door and it will say "ready to copy" instead of install toner or add toner /same thing with the i/u out of machine it will say ready to copy.any help is appreciated on these matters. thank you in advance.
taylor
taylor
