View Full Version : Miscellaneous Bizhub C252 PWB M compatibility
Sharanman
10-07-2010, 09:47 AM
Can anyone tell me if PWB M in a C250 would work in a C252. i have a touch screen issue that has had the panel replaced and only worked for a day, and now does not respond to anything. Tried calibrating cant get tech rep to work obviously. The panel does work on another machine so i was thinking PWB M if not then MFP. i would appreciate any thoughts
thanks in advance
Stirton.M
10-07-2010, 10:55 AM
According the the parts manuals, the numbers are different, so I would say no.
But....and this is a long shot, they might be compatible. The first 4 numbers of the part number, 4038, usually denote a specific machine family. The second set of 4 denotes the specific part in that family and the last two denote the version. In this case, the part number for the C252 is 4038 H001 01, and the part number for the C250 is 4038 0101 05. Do not quote me, as I do not have access to an inventory database to indicate if the older C250 has been superceded to the newer C252. Contact your nearest KM Parts department for clarification.
Sharanman
10-07-2010, 11:15 AM
i did look at the part number and wondered if they were the same, i will have to try it as KM are a bit away with the fairies at the moment. So getting a reply could be difficult
Stirton.M
10-07-2010, 11:24 AM
You run the risk of making things worse without verification.
Sharanman
10-07-2010, 12:28 PM
have now changed the board and no difference, managed to find a new one genuine 252 that was lying around.
jotunn
10-07-2010, 09:13 PM
In my oppinion this is not a problem with PWB-M or PWB-MFP, I'll bet blown ICP on PWB-C (Image processing board - under the scanner) near the connector of flat cable leading to the control panel.
Look for small black element 2x3mm (in surroundings you should be able to find description: ICP1), and as I remember it should have value 1.8A
