View Full Version : Removed sd-503 finisher machine says its still there (c252)
dinkyoaf
10-07-2010, 10:39 PM
Technician removed the SD-503 finisher off of a BizHub c252 but the machine still thinks it's there. Did he miss a jumper or some other important step?
Choclit007
10-09-2010, 02:33 AM
So was the SD-503 Saddle Stitcher removed from the FS-514 only or was the FS-514 finisher removed/unplugged from the copier...?
If only the SD-503 was removed was the adjuster plate screw loosened and moved back towards the copier? Were the upper tray guides moved back up one level?
jma676
10-09-2010, 03:04 PM
Ok, you need remove "Short Connector" in the FS-514, check installation manual.
dinkyoaf
10-11-2010, 04:55 PM
Anyone have a PDF version of the manual I could have by chance?
B0265
10-11-2010, 08:26 PM
This might be a dumb question, but did he remember to remove the creasing unit?
