View Full Version : Jamming B350/250
francois
10-08-2010, 01:40 PM
hi, did any one had a problem on the duplex turn over unit that couses the m/c to jam. is sounds like the motor that is not turning, we replaced the motor, the sensor and the soliniod but the same problem is stil there. i have it on 4 m/c and on a B420
fixthecopier
10-09-2010, 01:28 PM
I am not sure I understood the last thing you said. If you were saying you have a duplex problem on a bz420, then you have 2 motors to change. I have not had a bz 250/350 duplex problem, unless the problem was the switchback unit. If you want to narrow it down, pull the switchback and duplex and go to another machine and test them.
francois
10-11-2010, 08:00 AM
i have switch the switchback unit with another one, still the same problem. i even upgrade the firmwere on the m/c. the sound what the m/c is making sounds is a grr,grr,grr. i have swap all the boards inside the m/c aswell.
fixthecopier
10-11-2010, 11:56 AM
Did you swap the duplex unit?
Cantechman
10-12-2010, 11:00 PM
Maybe the duplex clutches?
francois
10-13-2010, 09:12 AM
i have swap the duplex unit with a new unit and stil the same problem
fixthecopier
10-13-2010, 10:32 AM
If you have swapped both the switchback unit and duplex, you may want to look at pwb "A"
Cleveland Tech
10-13-2010, 11:24 AM
replace the board on the back of the machine, I had the same issue and ended up replacing that pcb. that should do the trick if you replaced the other stuff in the switchback unit.
francois
10-18-2010, 11:27 AM
hi, i have solve the problem, it was the drum unit, when i swap the drum unit the m/c is working 100% without jams or aboard codes. thanks for all the help you gave me.
BR549
10-18-2010, 05:35 PM
I was just about to say change drum unit but I see you figured it out. I had this problem. The drum had a wear line all the way to the bare metal. It arcs to the charge corona causing weird problems.
