View Full Version : 6501 yellow toner problem
tech51
10-08-2010, 07:01 PM
Hi all, have spent most of today on a 6501 which is coming up c2451 (low yellow toner concentration in dev unit). On inspecting the m/c I found the yellow drum to be coated with toner. I put the magenta dev unit in the yellow position with the same result. I fitted new corona units swapped drums around and fitted new potential sensors all to no effect. I`ve come to the conclusion that the HV has failed and there is no charge on the yellow drum and have ordered the HV boards, but I would be interested to see if anybody out there has had a similar fault. Looking forward to your replies...51
Stirton.M
10-08-2010, 11:34 PM
you may have a failure in the yellow dev unit itself. I had a similar code today but with the black...replaced the unit and developer in it and carried on....
The PRCB controls that sensor.
tech51
10-16-2010, 05:40 PM
Problem solved, it was HV1 failure.
texchar555
11-03-2010, 03:42 AM
I had the same problem on Monday. I went to I/O and ran 54-00 ran the numbers until it got to 128 than ran toner refresh. and it worked . Ive done this 2 prior times .
tech51
11-04-2010, 07:59 PM
Thats fine if its just gone undertoned, but in my case it was impossible to tone it up. As a foot note to all this, I had the fault again at a different customer about a week later and that was a HV1 failure as well. Sods law I suppose but at least theyre both fixed now!!!
