View Full Version : changing default smb resolution on the bizhub c352
n25an
10-19-2010, 03:24 AM
I know you can go in from pagescope and change the resolution via programming under scans.... but I am wondering if there is a way to go into the copier with the utility key to change the default smb resolution settings?
Stirton.M
10-19-2010, 10:01 AM
in a nutshell, no. Not unless you want ALL scan types to be set to the resolution you want. Bear in mind that if you want compact pdf, your resolution options are limited.
n25an
10-19-2010, 01:10 PM
yes I want all scan types set to the same resolution
TheOwl
10-19-2010, 11:25 PM
Press 'Scan' and the 'Scan Settings'.
Now setup everything that you want defaulted such as resolution, file type, colour.
Once this is done, press 'Utility' - 'User Setting' - 'Scan/Fax Setting' - 'Default Scan/Fax Setting'
You should now be presented with two buttons. Current Setting and Factory Setting. If you machine is set to Factory, then press Current Setting. If your machine is already set to Current Setting, then touch it again.
n25an
10-20-2010, 02:31 AM
thanks
