View Full Version : C0211
ukyo
10-23-2010, 12:44 PM
I have a problem on C450 with the error C0211. I have replaced the solenoid, sensor & clutch but still it won't work. Any ideas?
albasoul06
10-23-2010, 10:12 PM
CAUSE: The drive gears in the manual bypass are not rotating.
SOLUTION: To verify if the drive gears are rotating in the manual bypass tray, perform the following procedure:
1.Remove the manual bypass cover (# 4036 3856 02).
2.Manually rotate the white drive gear on the left side (# 4131 3004 02).
3.If the gear rotates freely, it is possible the frame holding the drive gears is deformed. The gears should not rotate freely and should be locked in place.
4. Replace the frame (# 4036 0240 02) if is necessary.
