View Full Version : Miscellaneous Bizhub C250 Transfer Belt Cleaning Assy Problem
abscopiers
10-28-2010, 06:05 PM
Toner backs up in TB cleaning assy. Replaced with new belt and waste toner bottle, same problem. Any ideas?
Stirton.M
10-28-2010, 07:28 PM
check to make sure the cleaning auger is rotating freely. Unfortunately this means a lot of work to tear into that section, but a visual inspection is the only alternative.
suso73os
10-28-2010, 07:45 PM
I found a similar problem some time ago, When I got to the client house I saw that the waste bottle was full (I donīt know if you found the same problem), there is a small tube between the transfer and the waste toner, in this tube I saw waste toner stuck on there. So the waste toner canīt go into the waste bottle.
