View Full Version : Electrical Is tandem copying and printing available ?
kmcopytech
11-06-2010, 03:00 PM
I have some konica machine (K7075 7085 7255 7272 7155 7165 and 750-920-1050), bizhub600 -
How to set tandem copying and printing ?
Any solutions?
Thanks!
kmcopytech@gmail.com
Jack smith
albasoul06
11-07-2010, 12:43 AM
except bizhub 600 and 750 the rest have TANDEM
pepper38_cnd
11-07-2010, 02:46 PM
You are better off setting 2 machines up individually and manually splitting the jobs ie: if you have a 5K job send 2500 to each machine. If I remember correctly the Tandem setup means you have 1 printer interface and the jobs are split between the 2 print engines. This means you loose the ability to have a different print job running separately on each machine, ( someone correct me if I am wrong on this, we only set up Tanadom once , and removed it because of this issue), copying is not an issue.
kmcopytech
11-07-2010, 03:20 PM
Can you provide Tandem setup/installation procedure for K7155 K7272 K7085 and bizhub 1050 series?
Thank you!
jack smith
