View Full Version : Bizhub C5500 - C3801 error code
MFPTech
11-25-2010, 06:16 AM
What is the following error code related to please?
Thanks in advance!
dogsbody
11-25-2010, 07:21 AM
Fusing low temperature abnormality. Could be any of the temp sensors, lamps, AC driver board or printer control board, or it may just need to be reset.
Cheers.
Mr Spock
11-25-2010, 02:48 PM
This can occur if the paper weight is not set correctly.
MFPTech
11-28-2010, 03:28 AM
reset the Switch 3 - 1 to 0 and I got C-3902
cleaned the one-way bearings in the fuser, reset the error again and now I am getting C-3903. The lamps, thermostats and thermistors look okay with the multimeter.
Any ideas, please?
Thanks in advance,
CKiiza
11-29-2010, 05:26 AM
That's for:
Fusing high temperature hardware
detection abnormality.
Temperature sensor/4 (TEMS/4)
detected abnormality signal continuously
for the specified time.
check one of the sensors you touched or workefile:///C:/Users/Moses/AppData/Local/Temp/moz-screenshot.pngd on. might have a problem
