Bizhub C203 pass
  • arhonta
    • May 2025
    Bizhub C203 pass
    Hi guys, I have problem with the CE password and administrator pass of 1 KM C203. PLS help me to change it or remove ti...10x!
  • spock
    • 41
    Administrator password should just be 12345678, unless it has been modified. CE password could be anything but a popular one is 92729272
    • backspace
      • Jul 2009
      • 54
      I have the same problem. I tried with passwords "12345678" and "92729272", but nothing
      • spock
        • 41
        well you can reset the admin password in CE mode but i am not sure if you can reset the CE password without replacing parts on that model. It might be possible with a full run up again maybe someone else can offer advice on that part as ive never had to do it before.
        • arhonta
          What happens if I pull out and let the machine NVRAM, and then go back and reset? The problem that I have is that the machine is lifted "It is time for sheduled inspection of device" that procedure is done every 50 000 copies. But I do not remember whether resetting is administrator or technical menu. If anyone has suggestions to write. Good luck!
          • racosta
            • 53
            Try these steps....Hope this helps....
            11.3 Settings in the Enhanced Security
            11.3.1 CE Password
            11.3.2 Administrator Password
            F
            unctions • To set and change the CE password.
            Use • Use to change the CE pass
            word.
            Setting/
            Proced
            ure
            • Enter the CE pass
            word (8 digits) on the on-screen keyboard.
            • The initial setting is “92729272.”
            C
            urrent Password : Enter the currently using CE password.
            Ne
            w Password : Enter the new CE password.
            Re-Inp
            ut Password : Enter the new CE password again.
            NOTE
            • When the following setting leads to the Password Rules [ON], the password
            with the same letters as well as the password which is same as the previous
            one cannot be changed.
            [Administrator Settings]
            [Security Settings]
            • NEVER forget the CE password. When forgetting the CE password, call
            responsible person of KMBT.
            F
            unctions • To set and change the administrator password.
            Use • Use to change the administrator pass
            word.
            • Use this f
            unction when the administrator forget the administrator password because
            a ne
            w password can be set without entering the current administrator password with
            this.
            Setting/
            Proced
            ure
            • Enter the administrator pass
            • The initial setting is “1234567
            8.”
            Ne
            w Password : Enter the new administrator password.
            Re-Inp
            ut Password : Enter the new administrator password again.
            NOTE
            with the same letters, the password which is same as the previous one and the
            password of less than eight digits cannot be changed.
            [Security Settings]
            • racosta
              • 53
              11.3.4 CE Authentication
              • It
              will not be displayed when the following settings are set to “ON”.
              [Security Setting] [Enhanced Security Mode] or [Password
              R
              ules].
              F
              unctions • To determine whether or not to authenticate CE password as entering Service Mode.
              Use • Use
              when authenticating CE password as entering Service Mode.
              NOTE
              • For setting the following setting to “ON”, set the CE Authentication to “ON”
              and change the initial CE password beforehand.
              [Password Rules]
              Setting/
              Proced
              ure
              • The defa
              ult setting is OFF.
              ON “OFF”
              • arhonta
                R
                ules].
                F
                uwhether or not to authenticate CE password as entering Service Mode.
                NOTE
                [Password Rules]
                Setting/
                Proced
                ure
                ult setting is OFF.
                Try these ways, but without result. Other ideas?
                • xmasvn
                  • Jul 2009
                  • 70
                  that way you only work with default pass, but when you forgot pass you can reset by this way , i still looking for the way to reset the CE password
                  • arhonta
                    Well write if you can find something.
                    • RRodgers
                      • Jun 2009
                      • 1947
                      I remember them saying in class, if you change the CE password and forget it..... forget it! you might need a new NVram. KM might have a back door if you call them, course I don't think they give it out.
                      • xmasvn
                        • Jul 2009
                        • 70
                        that is they said but no one in this forum do that, or they do that but keep secrets for them self i have discussion alot in this problem but no solution to take over this solution
                        • Stirton.M
                          All things Konica Minolta
                          • Oct 2009
                          • 1804
                          If there was a way to reset a CE password without knowing the changed password, I am not privy to it. Not like it is a secret or anything. NVRAM reset firmware might work, but I have my doubts.
                          "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                          ---Groucho Marx
                          Please do not PM me for questions related to Konica Minolta hardware.
                          I will not answer requests or questions there.
                          Please ask in the KM forum for the benefit of others to see the question and give their input.
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            when you initialise the NVram it resets the CE password too.
                            but from memory you have to totally setup the machine again from scratch and perhaps even format the hard drive - i cant remember.
                            • arhonta
                              I knew from colleagues that can be reset but they asked for my serial number on the machine. Someone will tell me? arhonta@abv.bg
