Okay.. so there is NO code number....but I have a client who is using a Bizhub C650 to print posters and letterheads from a Mac and every time they send documents to the printer the C650 requests a different weight of paper other than what he has programmed into the machine. It's as though the printer software is pre-programmed to select the weight of the paper for specific jobs even if the client has pre-programmed the type of paper that they actually want to use prior to sending the file to the printer yet I can find no settings anywhere in the document file to make changes.
For example: if they select a document file from their archive that should print on 11X17 64lb gloss and program the machine for that style and send the job to the printer, the C-650 calls for an error and suspends the printing process and instructs them to install 11X17 85-100lb gloss even though they don't want it on 85-100lb gloss. If they program that type of paper in sometimes it still won't print.
Strangely enough, when the bypass is programmed for a specific waeit ans type, it doesn't recognize that it has that stock in the bypass, though 8.5X11 works every time...(we know the paper size sensors work)
Does anyone know if there is a way to disengage or reset the programming to allow them to use the paper they want in the machine or is this something in the way the original document was saved on the Mac?
Any information would be helpful.
Thanks in advance
Thanks in advance
