View Full Version : Konica Minolta CF2002 not working
violet
12-01-2010, 08:10 PM
Side door open message. Door is closed and customer has a chair leaning on door to make sure door is closed. Still has message and will not work.
mrwho
12-01-2010, 08:32 PM
Simple things first: Did you check for the switch/sensor that detects the door open/close operation?
TheOwl
12-02-2010, 03:42 AM
There are also two clips that break quite commonly.
Check the latch for the side door and make sure that both ends are indeed in a good condition. Sometimes they will crack and not break which also can give a similar problem.
RRodgers
12-02-2010, 03:44 AM
As Owl has suggested check the hooks that hold the door closed. They are common to break.
