View Full Version : Installing a bizhub c350 on mac os x 10.6
n25an
12-10-2010, 05:58 AM
my bizhub only has pcl.... no external fiery...
I have been able to get it working by using a an HP driver but this only prints black and white... is there a compatible hp driver that will let me print in color on my bizhub c350
jamie_t2005
12-10-2010, 09:30 AM
Hi i'm having the same problem at work we have 4 macs of which the C350 is installed fine on using a fiery driver but on our new macs we can't install the fiery driver. I am only able to print black and white.
Any help would be appreciated
Jamie
jamie_t2005
12-10-2010, 10:01 AM
Found a solution here Download Result - Download Center | KONICA MINOLTA (http://www.konicaminolta.co.uk/business-solutions/support/download-center/download-result.html?packageId=31028&productName=bizhub%20C350CS) if you download that and run the installer (I had to run the installer twice before it worked) you should then be able to select the driver software and it should work
n25an
12-10-2010, 06:53 PM
OK... I GOT IT WORKING... NOW HERE IS WHAT I DID... OOOOOHHHHHH
1. I installed Ghost Script
2. I installed Gimp Print
3. I installed HPIJS FOR MAC OS X 10.6
4. I installed FOOMATIC RIP
5. I setup an ip print driver with the hp color laserjet 8500 hpijs pcl 3 3.10.6.15
6. I went to localhost cups printing system (http://localhost:631/)
7. I selected the ip printer I installed and selected printer options
8. I changed the printer mode to color
9. I saved that option
10. I went to safari to print
11. I selected files, then print, then printer features... I changed output mode to black and white... I saved it as a new preset... then I printed a document in color from a bizhub 350( with no internal fiery)
