View Full Version : bizhub C452 small cyan dots on every printout
kizi57
12-11-2010, 05:05 AM
hi
I now got almost 64000 impressions, i mostly print A3 size and the machine started to print very small 3 - 4 dots, cyan in color in every printout of the a3 paper
what could be the problem?
CKiiza
12-11-2010, 08:30 AM
Does it do these dots appear allover the printout A3 or any other paper size or just in A3 alone? check the cyan IU, specificly the drum. rotate it it most likely you'll find the source of you dots
kizi57
12-12-2010, 02:49 AM
Thank you for the quick Response sir,
the dots mostly appear on A3's they're two to three dots per page, i will try to check if i can eliminate it from the CYAN IU.
