View Full Version : Konica 7050 error 35-1
ADS
06-06-2007, 07:29 PM
I need help does someone know how to reset this code. Or how to fix it
35-1
Flash
06-06-2007, 10:38 PM
Go into the 25 mode address 47 and change back to a 0.
ADS
06-08-2007, 02:47 PM
hello, now i don't have any display on the copier????
Just to check i hold down 25 then press on go into the p mode then scrol down to 47 and hit print to set to zero?
thanks
dogsbody
06-09-2007, 05:14 AM
The way I do it is enter 25 mode, press P, 4, 7, P, 0, start.
konitech
06-10-2007, 07:37 AM
check for a bound main motor or paper feed drive motor if you've got a combination of a blanking screen with a 35-1....otherwise, work the code.....either way, you'll still have to reset it
