View Full Version : FS-1128MFP Envelopes
tmaged
12-20-2010, 01:53 AM
I know, I know, I've tried to get them to use the ink jet. Does anyone have any tricks to get them to work without wrinkling ? We've tried different types. They worked fine initially. The hotline had us replace the fusing unit, but the problem persists.
kingpd@businessprints.net
12-20-2010, 09:23 AM
Never had much luck with envelopes on copiers and printers. Switch to window envelopes, much nicer and easier to deal with.
madas
12-20-2010, 07:43 PM
Hi, Tony
try these if you can get them in your part of the world.
} Use DL Envelopes from Tudor and Officeworks DL Peel-n-Seal
which are certified for Laser Printers. they have been the best to use. so i am told.
good luck LOL
madas
blackcat4866
12-21-2010, 01:28 AM
Doesn't this one have envelope levers to reduce fixing pressure? =^..^=
tmaged
12-21-2010, 01:42 AM
No pressure lever on these little puppies. I did get this gem from our ASM. The funny thing is, I inquired from the hotline since the 1300D, which the 1028/1128 is based off isn't off the sheet. They were not aware of these.:rolleyes:
madas
12-21-2010, 02:00 AM
Hi Tony
see attached for the pressure levers on the FS-1128.
madas
tmaged
12-21-2010, 02:17 AM
Thanks for that Madas ! I'll talk to the tech that went there. He called the hotline & I don't remember anything about pressure adjustments for the fuser. I searched "envelope" in the PDF and it never said anything about it. There is plenty in the end user guide, but nothing about the pressure.
DWise
12-27-2010, 03:29 PM
Any updates on this problem?
tmaged
12-28-2010, 01:40 AM
As of right now, I handed it back to sales. I told him we could try it if they insisted, but it's in a law office with little old ladies. I don't think they want to go to the hassle that it will entail.
Our Kyo ASM & the hotline did not realize the pressure release levers were on the 1128mfp.
DWise
12-28-2010, 01:58 PM
That's pathetic!!
