View Full Version : Canon IR 3300 system software
xcopytech
06-07-2007, 10:57 AM
Hi,
Need system software for Canon IR 3300.
Have fault code E 602 and need software to upload on HDD.
xcopytech@gmail.com
Thanks.
Regards
11x17
06-07-2007, 10:51 PM
You Also Need A New Hard Drive
gateway.vly@gmail.com
05-12-2009, 09:27 AM
CAN YOU HELP ME TO FIND MEAP APPLICATION FOR CANON iR 2570Ci
I CAN'T SCAN FROM PC I INSTALL SCAN GEAR IT SAYS SCANER OFFLINE
Hi,
xcopytech@gmail.com
Thanks.
Regards
bnmand
05-12-2009, 01:40 PM
Have a look in the Reference Guide for the copier. ScanGear is for pull scanning, that is you go to the copier and turn the scanner online and then pull it using a program to scan the files with the aid of scangear on the computer.
On the IR3300, you press the Options button on the copier and turn the scanner online. It may be a similar button on the IR 2570Ci.
Jack.au
04-30-2010, 06:30 AM
Hi guys:
My Canon iR3300 got a serious problem, the error code is E-602. I had SST and need iR3300 system software.
If somebody can help me, please send to my mailbox: lijia.sydney@gmail.com
Thx a lot.
Bolla
04-30-2010, 06:50 AM
Dear sir,you only need to replace the harddisk,then it is will be ok
Jack.au
04-30-2010, 07:25 AM
Hi, Bolla:
Just change a HDD is not enough, you need to format the new HDD and install some system software I think.
I had SST, but I don't have the systemsoftware.
Please help me.
bnmand
04-30-2010, 01:29 PM
Yes. You do need to format the hard drive and install the system software (both are done using SST). What you need to install depends on which version of the 3300 you have and what options you have installed.
Do you have the 3300 or the 3300i? If not the 3300i, do you have a network card installed?
Jack.au
04-30-2010, 01:39 PM
Hi:
Yes, I had a 3300, with print version. So it has a network card on it. I know there is another copy only version 3300, it's not my machine.
But I don't have the system software. And I couldn't find it on net:(
If you had it ,please sent it to me: lijia.sydney@gmail.com
Thx a lot!
I need SST for System software for ir 3300
please mail me: amarpuri6@gmail.com
Thankz
Hi,
xcopytech@gmail.com
Thanks.
Regards
gizmorale
03-17-2011, 04:32 PM
this HDD problem is suck isn't it? one said must use firmware that until today cant find it anywhere, other said need system software which is dont have either and hard to get anywhere too.
so all i have to do is find both files, and try it one another. so please, if, someone know where i can get those files, pm me.
btw, is it legal for a common (uncertificated) technician to have it? read somewhere if only certificated technician can have those files and do the installing process.
if it's legal, then how can it's so damn hard to get those files and program to run it?
sorry for my bad language.
