View Full Version : C350 with code C0f3B
toddanderson
06-07-2007, 11:08 PM
Went on a call that had a blank line on the magenta test print
So I replaced the magenta unit and than I get a C0f3B code with the new magenta unit
Any help I am a new tech here
Scott_Lewis
06-08-2007, 03:15 AM
I can tell you it is a "Magenta ATDC Sensor adjustment
failure".
Try reseating the IU, shake the IU to distribute the developer evenly, reseat the IU, check for damage to the connector, reseat the IU, get another IU, shake well before intalling, reseat the IU.
I've had this before. Can you guess what has worked for me? :>
These are the 'official' solutions from Monica:
SOLUTION:
1. Clean the ATDC window on the bottom magenta imaging unit.
2. Clean the magenta ATDC sensor LED.
3. Replace the magenta imaging unit.
4. Replace the PWB-I/O board.
mitchl
06-15-2007, 04:34 PM
failure".
SOLUTION:
5. Replace machine.
6. Purchase a magnum of Grey Goose and drink heavily!:p
JustManuals
06-15-2007, 07:11 PM
5. Replace machine.
Very helpful Mitch, you're gonna be very popular here (while you last)
Paul@justmanuals.com
mitchl
06-15-2007, 07:57 PM
I can tell your the humerous type already. Maybe I should have tried to sell him something!
hold IU flat and shake a few times to even out the developer and try again.
knightfall
06-16-2007, 12:05 PM
beware if you shake outside the wrapper it came in the developer may leak out when being shaken, its already happen to me.
i'll refrase, shake it "gently" to even out the developer inside.
on a similar note, thats why the boxes are not square on the ends-to prevent you from stacking the units on thier ends................
T6895
06-18-2007, 05:13 PM
You might want to save the magenta unit, K/M is having problems with them right now and there is a retro fit kit for it.
dudley
07-03-2007, 04:23 AM
If shaking doesn't fix the problem, then use some needle nosed pliers to turn the developer drive coupling by hand to free it up. The drive is the white plastic coupling at the back of the IU to the right of the drum. Then shake lightly again.
