View Full Version : Canon IR HDD
xcopytech
06-08-2007, 01:00 PM
Hi,
Does anyone know is it possible to replace original System 20GB HDD in Canon IR series with bigger 40 or 60 GB.
Also still need system software for Canon IR 3300.
Thanks.
Regards.
Kopyrtek
06-08-2007, 04:08 PM
You can use a bigger HDD,i think it will only "see" the size that it needs to operate.
Copier_Guy
06-08-2007, 11:36 PM
You can use a larger drive but it has to be encoded for Canon, otherwise the system software won't load using the Service Support Tool.
Kopyrtek
06-09-2007, 01:59 AM
Thanks copierguy,i forgot about that.The drives we use are Toshiba,they are the most likely to be good for Canon.
xcopytech
06-09-2007, 08:00 PM
Hi,So I can use some of toshiba HDD for laptops. Is there any remarks for those HDD`s or I can use any toshiba laptop HDD.Thanks
Copier_Guy
06-10-2007, 05:07 AM
No, you have to use a HDD that's specifically encoded for Canon iR devices. You have to buy them from Canon, although I understand there are a few aftermarket companies that sell them. They don't always work so well, but for the most part, they will do the job. I beleive the HDD's are made by Toshiba, and now that I think about it, the specs (Size) have to be the same as the HDD you remove.
Canonzac
06-20-2007, 04:03 AM
No it is not possible because of the systems software. It might allow you to use it but it will not use all the harddrives memory. The software has set partition in it.
freedomtt
07-31-2007, 06:18 PM
You can use a Toshiba HDD not purchased from Canon. If you have the SST you can load the system software onto the blank HDD. This is what we do everytime we need to replace a HDD, it is by for more cost effective.
Copier_Guy
07-31-2007, 06:21 PM
What Vendor do you get those HDDs from?
freedomtt
07-31-2007, 07:02 PM
Most recently we purchased the hard drives from Computer Giants. We have used other vendors in the past but I don't have the info handy. If my memory serves me correctly I believe they were around $50 each.
Copier_Guy
07-31-2007, 11:31 PM
Thanks Freedomtt. I'll check them out. That's a great price.
RedRed
08-16-2007, 03:32 AM
We also use the Hard drives from Computer Giants. Great $$$ savings. You can get the 20G or the 40G ( Needed for the iR2220 and iR3320 models) We Have also used them in the new 70 and 30 series. Memory Experts sells them too. Cheaper than Canon but more expensive than Computer Giants.
indyman73
08-22-2007, 01:49 PM
Just an fyi...If you go into the c:\ServTool folder, where all the service files are stored on your pc. Then find the model you are looking for, there should be a folder called HDFormat. In that folder there should be 1 file that should look something like iR2200-XXxx0007-HDFormat.ift (depending on the version). If you copy that file to your desktop and then change the "ift" at the end to "txt", you can see all the Hard Drives that will work with that particular model. I usually look on a website at Compuvest Corp. (http://www.compuvest.com) for the Drives. You can get new and refurbished, they have been pretty reliable. Just make sure that you look for the right drive, since the list does show more than just the regular 9.5mm laptop drives.
safedeepblue
09-22-2007, 08:42 PM
wwwooow
demitricco
11-08-2008, 02:42 AM
where can i buy canon service support tool for ir6000? can you help me find them?
my payment method only a bank transfer...
thanks
junkiemanxl
11-08-2008, 03:36 AM
I have success for the following brands of HDD for the IR3300-3320i series.
Hitachi 80gb
western digital 80gb
Toshiba 80gb
I'm pretty sure most HDD regardless of brands are able to do the job just as long as the RPM speed onthe HDD is compatible.
I'm using a clone software system to get my disk configured.
anothertech
11-08-2008, 04:54 PM
junkiemanxl, what clone software do you use to set up the new hard drives?
Just an fyi...If you go into the c:ServTool folder, where all the service files are stored on your pc. Then find the model you are looking for, there should be a folder called HDFormat. In that folder there should be 1 file that should look something like iR2200-XXxx0007-HDFormat.ift (depending on the version). If you copy that file to your desktop and then change the "ift" at the end to "txt", you can see all the Hard Drives that will work with that particular model. I usually look on a website at Compuvest Corp. (http://www.compuvest.com) for the Drives. You can get new and refurbished, they have been pretty reliable. Just make sure that you look for the right drive, since the list does show more than just the regular 9.5mm laptop drives.
And just a further note on .ift files...
Canon releases updated .ift files each time a new compatible HDD is found.
Make sure that you go to your regional Canon site and download the new .ift file and place them into your SST folder.
For MANY of the machines this .ift file can be modified although...I heard the latest gossip from Canon.inc the other day and they are going to begin encrypting ALL .ift files from now on.
They've already started with the new C7000 series....you CANNOT use a generic HDD in that machine.
perpetualjon
11-26-2008, 07:03 PM
Then wouldn't it be prudent to make a disk image the moment the machine arrives in an office and keep it on record somewhere in the even that the drive fails? At least this way all the special encryption that Canon puts in is restored without any problems.
junkiemanxl
11-27-2008, 12:11 AM
I use acronis true image home to clone the HDD. One of the best and easiest software to use compared to a few that i have tried.
Ir2200
Fujitsu MPC3032AT
Fujitsu MPD3043AT
Fujitsu MPE3064AT
Quantum FireBall CX6.4A
Quantum FireBallLct10 05
Quantum FireballLct08 04
Quantum FireBallLct15 07
Fujitsu MPF3102AT
Toshiba MK6014MAP
Toshiba MK6015MAP
IBM-DJSA-205
IBM-DARA-206000
Fujitsu MHK2060AT ST34311A
ST34313A ST310211A
Fujitsu MPG3102AT E
Quantum FireBallLct20 10
Toshiba MK1016GAP
IBM-DJSA-210
Fujitsu MHN2300AT
Toshiba MK6017MAP
Maxtor 2B020H1
Maxtor 4K020H1
WDC WD300AB-00BVA0
Samsung SV2001H
Maxtor 2F030J0
ExcelStor Technology J120
Samsung SV0211H ST340015A
Toshiba MK2023GAS
Samsung SV0221N
Toshiba MK2023GAS ST92011A
Hejsan
11-28-2008, 10:04 PM
Guys, I have been trying for several months to find a solution, but could not do anything. I'm looking for HDD image (preferably generated by Acronis TrueImage), for my iR3300 (with network support). I would be very grateful, if you could put this image somewhere on any FTP server, or share it through the torrent system... Please... I really tried everything, but can't put the firmware on a new HDD.
Thanks!
Phantom Tech
02-13-2009, 05:08 PM
Canon WM2-5216-000: Hitachi 20gig - HTS541020G9AT00 :D or this is the same drive - (13G1581) :)
Will work in the following Image Runners and maybe others - I haven't updated this in about a year
85 105 2230 2270 2830 2870 3025 3030 3035 3045 3530 3570 4570 5070 5570 6570 8070 9070
Canon WM2-5222-020: Hitachi 40gig - HDS728040PLAT20 :D or this is the same drive - (0A30209) :)
Will work in the following Color Image Runners and maybe others - I haven't updated this in about a year
ir60 85 105 550 600 5000 5020 6000 6020 7200 8500 irC3100 3200 3220 5800 6800
Canon is over $300, BUT you can find them on the Internet for less that $50 with 1-3 year warranty
Phantom Tech
haydar64
02-14-2009, 12:18 PM
i am using 120gb 2.5" seagate IDE disk at all canon machines, and i'm cloning all model's disks, ,HDD model is not matter, i have no problem.
when u buy a new machine; first: take it's hdd for clone for archive :)
Like me :D
cost is maximum 50-60$
haydar64
02-14-2009, 12:21 PM
Thanks!
Sorry Hejsan, it is not possible, because, u must clone 1 to 1 this disks, otherwise, machine is not run...
when i take image from original disk , make a copy disk from this image, i'll see many more problem.
HAYDAR64
Hejsan
02-16-2009, 06:59 PM
Thanks, haydar64 for the info... It means that my iR3300 is not repairable :) I can not order it anywhere else except my country. We have a strange financial policy in the organization
Hejsan
02-23-2009, 04:44 PM
Thanks, Haydar! I already have the firmware and SST, but can not find appropriate HDD model
bnmand
02-23-2009, 11:31 PM
As a last resort you can try a similar HDD model to the one's listed in the HDFormat.ift file of the copier's firmware and use the instructions found in Copytechnet.com (http://www.copytechnet.com/forums/attachments/canon/520d1218187407-new-hard-disk-ir3300-sst_-_hdd_not_found.pdf)
I believe Oze a highly respected member of this forum uploaded the pdf instructions.
It's a bit hit and miss though with using a HDD not on the list. Some will work and others won't.
Yes you can.
First step you must format hdd with SST, if you can’t, try another first step: format hdd in windows in fat or fat32. After that it gone be possible.
I have already done that. It must be an ATA hdd.
Sorry my English. I’m to practice more! :(
time2fly
02-24-2009, 01:55 AM
I think the most important thing is that the HDD needs to be low level formatted first.
Hejsan
02-27-2009, 06:41 PM
Thanks guys! First, I'll try Low Level Format... Hope, it helps :)
davidj7
02-28-2009, 11:39 AM
Hi guys i am having a similar kind of problem with 8500. I need more space in the mailbox.But i am able to use the only limited space provided by Canon.is it possible to install a 80Gb or higher HDD in 8500 and use all the space.
bnmand
03-03-2009, 01:07 PM
I doubt it. Why would you need more than 80gb anyway? If you need more and its networked, put a computer next to it and store documents on that.
haydar64
03-03-2009, 01:58 PM
u can use ABBY FINE READER for scanning all documents.
i'm using it, and i can convert to word-excel files , .pdf files.
you have to try man.
davidj7
03-03-2009, 04:49 PM
haydar this is a stand alone machine located in a remote location . In office i am already using the option u suggested.Thanks anyway
rosaro75
04-02-2009, 01:50 AM
hai everybody don't go costly. buy any ide hdd any brand in any size more then 6gb. send me the hdd brand name and model no.detail. i will send you a hd format file. just replace it in your 2200 hd format folder. you see the unbelivable thing. those who interested send mail and enjoy. also for any model machine.
pearlpdy
04-02-2009, 08:50 PM
sir, pls send me hdd format file for all model and all type of hdd my mail addr is pearlpdy@yahoo.com
thanks for ur coperate
rosaro75
04-03-2009, 02:05 AM
hay i altered 3300 to use 3.5'' hdd that is bigger one.mfc board had provision to put a connecter for 3.5'' hdd ide cable. and i took 12v power for hdd from orange color wire which is almost dummy in mfc board box. and normal 5v from mfc board. i am sorry.i sold the machine. or i will show the photo
mtech
04-03-2009, 02:47 AM
I would think that if you needed 20G max, you could use a larger HDD and partition off 20G marking it primary/active and leave the extra space unallocated. Then load the system software onto the 20G partition. Never tried it though.
can anyone provide us with the latest software here for the ir5000 hdd. it would be greatly appreciated since i had 3 last month crash and burn. thanks t
cdvidaceiba
04-08-2009, 04:17 AM
hi , this is my "problem" with canon HDD
got some ir5000 ( c , n , dn , d ) and i want to make some back up hard disks , i got the same brand and model ( samsumg SV2001H) hard disk the machinne i am using has ... i had tried SST and gimme and error 150 that my disk is not valid .
i had tried to clone the hard disk and when i connect the cloned disk to the copier gimme and e602-001 ...
what can you recomend me to do
why if i got the same hard disk the SSt gimme that error code 150 and says that my hard disk is not valid
what hard disk you can recomend me for this model ir5000/5020 copiers
thanks in advance
cdvidaceiba
04-08-2009, 10:34 PM
ok i already found the "problem or my problem " i am using one of the first versions of HD format file , that just have fujitsu and quantum drives on it , anyone can provide me the latest system software for canon ir5000/ir5000c copiers
what i dont understand is why my cloned disk didint work....
rosaro75
04-09-2009, 03:18 AM
some clone tools makes partition copy. so the mbr will not copied. so you have to use sectorwise copying tool.that means disk to disk clone mode tool.
if you want to format using sst. just send me the hd format file to me. i edit it and send you. it must work
cdvidaceiba
04-10-2009, 11:56 PM
it works ,thanks Rosaro!!!!:)
bariseryener
09-08-2016, 05:02 PM
Hi Guys,
I Buy IR3225N and havent HDD. Connections is SATA. What can i do? I found SST but i am looking firmware or Disc Clone Image. Anybody can help to me:D
