View Full Version : konica1212
cliffhangers
01-03-2011, 07:46 PM
hi,this konica1212 is not displaying any code when you put it on,bet when press copy it pick the pepper and live it inside the hitter roller and it start display F28 when i remove the pepper jam off the copier and on, it came back good.and all the corona are good.please i need your help.thanks.
ebm
01-04-2011, 02:12 AM
Can't remember the last time I worked this model. But, if the F28 is the t/s corona error you can try removing the separator wire and see if it works. If it does, you can try cleaning the posts if it has corrosion or replacing the end blocks.
