My copies are lighter near the bottom 1 1/2 inches of the sheets..What could be causing this. I have swapped out the developer unit, the charging unit, the drum, and cleaned the transfer/sep unit..
Konica 7075 Copies Lighter Toward the front of the machine
Verify that the Dust Proof Glass is clean. Probably the laser beam isn't "getting" on the drum in that area.I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?Comment
Its usually soilage of the polygon mirror in the write unit. Take out the write unit, remove the units top cover and gently clean the faces on the rotating mirror. This should sort itComment
All the most probable causes were already mentioned, but if all else fails, check if the machine is level.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
