View Full Version : c452 WITH LINES
bsm2
01-07-2011, 12:44 AM
GOT A C452 WITH LINES THAT LOOKS LIKE THE mfp BOARD FAILURES ON THE C353 AND C451 SERIES MACHINES ANY INPUT WILL HELP THANKS
Stirton.M
01-07-2011, 05:29 AM
Could be a board failure, check firmware, do a factory reset (backup user data first), inspect connections and reseat. Use ledger size paper and see if the pattern repeats, it could be a damaged transfer belt.
emujo
01-07-2011, 02:11 PM
To me, the lines don't look like anything electronically induced, more like rubbing or stalling somewhere. What happens when you scan an original to a scan location? Are the lines reproduced? Emujo
bsm2
01-07-2011, 06:06 PM
Scan work fine, get lines on copy and print and internal printouts
mo0651
01-07-2011, 10:18 PM
Boy those look like laser dots. Seen those when a laser malfunctions. How about doing some single color copies and see if it is one IU or all 4. Might help tp narrow it down.
pepper38_cnd
01-07-2011, 11:44 PM
If I had to guess I would say the transfer belt cleaner is plugged up. Pull out the belt and see if the lines are on it.
bsm2
01-09-2011, 09:26 PM
pull transfer belt no lines on belts but on 11 by 17 line does repeat that is about the size of black drum ,but CQ look like the digital lines failures of the c353and c451 MFP boards?
Is there any word from konica on a special firmware for this model to address digital type of lines?
Mr Spock
01-09-2011, 09:56 PM
If it is a repeat pattern then I would try another drum and see if it goes away.
bsm2
01-11-2011, 02:07 AM
Lines in all 4 colors light gray about 1 inch band, check and reseated all drums,
mo0651
01-11-2011, 02:45 PM
Okay that sound like something stuck in t-belt cleaning blade. Stop the machine with paper at transfer and then look at belt. That lite gray sounds like waste toner not being cleaned.
lucky13
01-12-2011, 06:27 AM
what have you replaced so far?
bsm2
01-19-2011, 12:51 AM
black drum no change going to try MFP board do to the fact it looks just the c353 and c451 banding problem we had from the MFP Board on the previous model
kronical
01-22-2011, 01:50 AM
You said the deefect repeats on 11x17 sheet, is the defect always the EXACT same? Run the internal cmyk test pages, if you see black/grey lines throughout the colors, then i/u's and lasers can be eliminated. you would then be looking at tbu, secondary transfer, or fuser. If you say the defect repeats at about the interval of a drum rotation, i would check for ripples in the fuser rollers, as they are about the same size as a drum.
bsm2
01-27-2011, 03:25 AM
MFB board fixed it.
