View Full Version : Sending print job to c450 konica minolta data light blinks
copies
01-07-2011, 10:11 PM
When I send a print job to the c450 the data light blinks and the job never prints. This just started happening, any ideas?
pepper38_cnd
01-07-2011, 11:48 PM
What does it say in the job history? Is Account Track or Authentication enabled?
Stirton.M
01-08-2011, 01:11 AM
Or the job has been printed to a user/system box or secure print
copies
01-08-2011, 05:06 PM
There is nothing in job history and acct. track and auth enable are both off.
copies
01-08-2011, 05:07 PM
Secure print is not being used.
mrwho
01-08-2011, 05:33 PM
Maybe this is one for the NVRAM/NIC-reseting firmware-thingie?
Stirton.M
01-08-2011, 07:43 PM
Or just a wipe of the settings in tech rep, re-enter all the settings and so forth will correct it.
Might even be something as stupid simple as a poor network connection or failing port on a router.
aesthetics1
01-10-2011, 04:24 PM
Try printing to it with a crossover cable first.
Try a firmware update second.
Try a Data Clear third.
Report back!
B0265
01-11-2011, 07:05 AM
Can you print the demo page?
copies
01-12-2011, 09:58 PM
It will not print anything
copies
01-12-2011, 10:01 PM
I hooked up a crossover cable and I still couldn't print.
How would I do a firmware update or a data clear?
Thanks for your help.
acusso1234
01-13-2011, 01:14 AM
Can be a memory issue. Do not remember exactly where, but there is a way in to control the memory that are two tipes, solded on the main board and normal kind also.
Is better for you to try this first.
pepper38_cnd
01-13-2011, 11:21 AM
If you are correct in saying that you can't even print the internal Demo page, then this is probably an issue that is best handled by a qualified technician. Trying to do firmware or NIC resets and not knowing exactly what your doing will most likely result in a dead machine.
oldschool
01-18-2011, 03:56 PM
Is there a vending device attached? I've seen the exact symptom when one is attached. In Vendor 1 mode sometimes pass through printing does not work. There may be specific firmware needed or a soft switch that needs to be set. The hot line should know for sure. In vendor 2 mode there is a setting in admin/security to freely allow printing or to charge for it. In the case of charging for it, the print job has to be a secure print job.
musthafavi
08-24-2017, 05:08 PM
Whenevere i sent documents to print, the Konica Minolta c360 warms up for a period of time and just not printing, the data light keeps flashing and yet it's still not printing and unable to configure SMB/email scanning functions from public usermode
gl0ryh0und
08-24-2017, 05:33 PM
C450? wow, this device is way out of its service life. The problem you're describing could be a number of things. However I must ask.. have you rebooted the fiery? (IC-402) If so this has a different power switch in the back of the machine. Power cycle the fiery. If the fiery needs reloading, you will need a trained technician. It could also be the OACB, or the fiery died.. but in that case I'd just take it to the scrap yard and then take the proceeds and buy a snow cone.
