View Full Version : Error Code Kyocera KM 4050i Error Code c3300 - No Scan Lamp
ragajungle
01-10-2011, 04:09 PM
>On intialization the scanner moves freely back and forth-OK.
>On initialization the Scanner LAMP does NOT turn on.
>I also checked scanner motor ops in service mode-OK.
>Checked scanner lamp ops U061-Dead.
>Chacked DP Read U073-Dead.
>Cleaned and reseated all connectors-Still Dead.
I am wondering if the SCANNER INVERTER or SCAN LAMP are a common problem with these.
only 189,000 clicks
I was thinking scanner lamp assy or inverter PCB, am wondering what others have run into
Thanks,
Mike
blackcat4866
01-11-2011, 12:49 AM
It's not impossible, but I've never seen a bad exposure lamp or inverter on the Falcon III series machine. I've got machines over 1.5M prints.
The things you can do for free include pinning out the ribbon cable, and re-loading the firmware. Cost-wise, I would start with the lamp & inverter. It could also be the ribbon cable to light source 1 or the engine PWB, but I'd save those for the next round of parts replacement.
ragajungle
01-11-2011, 08:35 PM
Thank you Blackcat... I am about to go over there and do just that. My lamp and inverter PCB have arrived. I will post results.
ragajungle
01-12-2011, 08:48 PM
It was the lamp inverter PCB. What a PITA to get to.
blackcat4866
01-13-2011, 12:35 AM
Good diagnostics. Thanks for sharing. =^..^=
i have one time seen it be the lamp itself. sounds like a very uncommon problem though. luckily i had a parts machine to get it up and running the same day. customer called in with the code, sorry i dont remember what the code is now
Hi ! i run into this code [3300] today ,when i replaced lamp inverter no luck the code [3300] still appear so i replaced scanner board when i turn on the machine what i saw is exposure lamp light up a second and smoke coming the end point of exposure lamp .Of course the error code [3300] appear . Any idea to solve this faulty ! Tx:eek:
JustManuals
09-09-2011, 07:05 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
