set up scan on bizhub C350
  • alonzo
    • 63
    can someone help me or direct me on how to set up scanning on bizhub C350 is there a sight for setting up scanning for idiots. P.S. I also have to set up scanning on DI3510 the customer want alot from a copier tech who is not a IT guy.
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    scan to mail.pdf
    Here is a sample....sorry it is in italian.
    If you decide to setup a scan to SMB let me know, and say also which operating system is using your customer.
    p.s. I don't know if scan to mail works on the older box, i've started working on Konicaminolta only in 2005, so I know only the bizhub models.
    Have fun, and....as someone sign on this site:
    "Never argue with idiots. They drag you down to their level and then beat you with experience."
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • pspice2001
      re scan setup
      Make a folder on the desktop and call it scans. right click on the folder and go to properties. In properties give it full sharing rights. If you don't give the folder permission for full sharing your scan will never get to the computer and the machine will delete it.Usually takes me about 5 minutes a station. Good Luck
      • yousaf
        • Jun 2010
        • 43
        can u write it with details how to set scan to pc
        i can not set up this option scan to pc can u plz help me
        thanks
        bye
        yousaf
        • yousaf
          • Jun 2010
          • 43
          if u will help me i will b grate full to u. how to set up scan to pc in bizhub c350 customer is useing xp pro. can u send me every single step how to send scan to pc thankssssssssssssssssssssssssssssssssss
          yousaf
          • CT Copier Repair
            • Mar 2010
            • 304
            Yousaf
            Its called scan to pc it can be googled for steps
            call a technician
            • acusso1234
              Tecnico
              • Dec 2008
              • 250
              • stan780953
                • Feb 2011
                • 47
                Hi The C350 will not offer scan to folder the option you have are TWAIN, scan-to-FTP, scan-to-HDD,scan-to-eMail, scan-to-iFax, scan-to-Userbox. The Ftp option will allow the customer to point scans to a folder but requirers pagescope cabinet also scan to email doesn't support smtp authentication. The easiest way to get your customer scanning is to download box operator or if you have cd with m/c it will be on there and retrieve scan from the HDD.
                • Stirton.M
                  All things Konica Minolta
                  • Oct 2009
                  • 1804
                  Access to an assortment of pagescope software compatible with this model. Not all programs listed will work. Pagescope Cabinet is available to act as a FTP server.
                  The alternative is to simply upgrade the machine itself. Even a C351 is vastly superior to the C350, it allows SMB, authentication to SMTP, scan to box (internal hard disk) and more. The C350 is IMO a piece of crap, relatively speaking of course.
                  "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                  ---Groucho Marx
                  Please do not PM me for questions related to Konica Minolta hardware.
                  I will not answer requests or questions there.
                  Please ask in the KM forum for the benefit of others to see the question and give their input.
                  • emujo
                    • Jun 2009
                    • 3009
                    yousaf
                    It seems to me that every install is just a little different from the last, different OSs, different layers of security, different capabilities with each new MFP, different customer needs and so on...so to ask for a standard step by step instruction manual for setting up scanning is impossible. Take the advice posted here and tackle this yourself, or even better, call a trained tech and pay him/her for the 1-2 hours of time and get involved in the process. Ask questions and try the setup yourself. Don't just be satisfied that its "working now". If you can't learn, or don't want to, be ready to pay for the service. I can't fix the transmission on my car, and I'm not foolish enough to ask for a step by step document as I know I will just make it worse, so I take it to the dealer and pay for the job to get done correctly. But you can bet I can change the oil, replace the brakes, or an alternator, as needed. Emujo
