View Full Version : bizhub601 error c-2804
stratos
01-13-2011, 06:34 PM
Hi everybody!
after PM (500.000) the machine start giving errors like c-2801,c-2803,c-2804
The machine can only work with the cleaning blade to the release position OFF
can anybody help?
Desert Rat
01-13-2011, 06:42 PM
stratos,
Please tell us what it does with the blade on the drum? I had a 600 at one time and some of these machines
are prone to "blade flip". You could try re-powdering the blade and drum. After I powder a drum and blade
I will turn the drum opposite of the way it normally turns to prime the blade. Usually about a half a turn.
Also you may try using methusala powder. This stuff is really good and you will be able to notice a difference
in the resistance felt when turning the drum in the correct direction.
Hope that helps
DR
stratos
01-13-2011, 07:05 PM
when the blade is on it stacks the paper in front of the fuser
