View Full Version : Bizhub C450 problem
irakli3443
01-14-2011, 08:10 AM
when I printing some part is not print good
look at simple
please help
mrwho
01-14-2011, 08:23 AM
Cyan IU.
look at simple
Yup, that one's simple. ;)
tonerspot
01-14-2011, 08:29 AM
did you reset the IU ? maybe you need some developer on cyan IU
irakli3443
01-14-2011, 08:36 AM
and how can I check it? wich one have problem? Red Blue Black or Yellow?
Sorry for my littel English
mrwho
01-14-2011, 08:43 AM
Blue
Stirton.M
01-14-2011, 08:52 AM
*sigh*
Replace the Cyan image unit.
irakli3443
mrwho (http://www.copytechnet.com/forums/members/mrwho.html)
maybe problem in Toner?
ineo+6501
01-14-2011, 09:06 AM
Have you just had the BLUE IU chipped?
irakli3443
01-14-2011, 09:22 AM
I dont know.
I had this Machine 2 month, my friend presented it.
so I'm bigginer :)
ineo+6501
01-14-2011, 09:46 AM
Well in any case, you need to fit a new CYAN IU.
mrwho
01-14-2011, 09:51 AM
If you have another used Cyan IU, try it to see if problem changes.
Else you can try to add toner from the tech rep mode and see if problem goes away permantently.
If nothing works, then my betting money goes to a new Cyan IU.
irakli3443
01-14-2011, 10:10 AM
yes but some IU have life, look at attachemnt photo
some body said me the machine is probably at an angle, it's posible?
mrwho
01-14-2011, 10:14 AM
It is possible, but if that was the case, your machine would show that defect in all colours. Since only the cyan is failing, we're assuming your cyan IU was chipped (reset) and thus it is probably not new. Look at your Cyan drum: does it look entirely new? Or do you see a big difference between the edges and the center?
Stirton.M
01-14-2011, 10:15 AM
A level machine is important, but mainly to keep it from rolling around. If it was unlevel, you would see the issue in ALL the IUs, not just a single one. The IU's sometimes die prematurely.
As mrwho stated, the "add toner" command in tech rep may correct this issue and sometimes does, though not often.
Stirton.M
01-14-2011, 10:16 AM
JINX!
:p
KEVIN900
01-14-2011, 12:00 PM
To troubleshoot individual colors; On the panel, where you choose black or color copying, press "Single Color". Then you can make a sky shot of each of the colors. Make a Cyan print, a magenta print, a yellow print. Your sample is obviously cyan failure.
