View Full Version : How to Reset Copy Counter in IR Series ?
zombiee
06-13-2007, 07:52 PM
Hi,
I am looking for a solution which would allow me to reset the copy counter in IR 3300 / IR 5000 / IR 6000 Machines.
Does any one have any idea how to do this ?
Thanking You,
-Zombiee
10871087
06-13-2007, 08:24 PM
Hi,
Thanking You,
-Zombiee
Why would you need or want to?
canonguy
06-13-2007, 11:47 PM
What is your reason for wanting to do this?
zombiee
06-14-2007, 08:12 AM
Hi,
I am a software person who does Network Printer Installation and one of My customer want this.
If u can help me that would help me a lot.
Thanking You,
-Zombiee
canontech
07-27-2007, 11:27 AM
It cannot be done, the counter is a hard counter it does not have a soft reset, you must purchase and replace the counter PCB. (only available as a canon service spare part, can't be bought in a store or online.
By doing this your customer will be misleading themselves by thinking it's like a car speedo that can be wound back using a cordless drill.
Counters are important for error codes, jam codes, and the part counters. Each time a jam or error occurs a counter reading is attached to each instance so you can see how many copies between jams or errors.
Leave it be, it is more important to leave it alone.:cool:
mitsubee
08-06-2007, 03:12 AM
Hi all ,
About the Counter clear thing it can be done.But honestly i myself dunno how , why i said it can be done , cause myself also work as a tech in a copier recond company , all of our used machine that we order come with a " 0 " counter , simply because my boss have to pay for that services to get the counter to be adjust back to 0, i don`t think they change any counter pcb.
Copier_Guy
08-06-2007, 05:37 AM
Hi all ,
If you find out how, please share with us. Not that any of us would want to, but info is a powerful thing.:D
ben-copier
08-27-2007, 06:25 PM
This download requires Pando. Get it free! | Pando (http://cache.pando.com/soapservices/Package/package.pando?id=27B60664C260AABCDDE9C338E60580F24 B7D0E89&key=67963D1FC6429E6FD79B8C40C8D7813C517B280B51272E E650BE4FBEBE9A79DA&tt=S2W&embedId=874FE65C266B1AE9363BF2118AD938CF)
zkafs
08-28-2007, 08:52 AM
U WANNA KNOW HOW TO RESET IR3300 COUNTER I HAVE THE SOLUTION BUT ONLY THRU E-MAIL ONLY zaqmzm@yahoo.com.sg
Canuck
01-17-2008, 06:12 AM
Why would the customer want this..the only way that it would benefit them would be to sell the machine with a reset counter...thats fraud..tell them to take a hike...i work for canon and would lose my job for doing that(probably get charged and sued also)
wachira
01-22-2008, 11:07 AM
I have problem copier iR3320i error code E355 please help me. I tries clear error in service mode turn off/on but this error occur.
ben-copier
01-23-2008, 09:26 AM
You're playing with your counter pcb. sure e355 will occours.
http://www.bootrom.biz/images/Zero.JPG
PDL Boot ROM Converter / Duplication - Disclaimer (http://www.bootrom.biz/)
copierhunter
02-25-2008, 06:47 PM
pls educate me that how to reset the IR 3300 counter.
benjamin
02-29-2008, 04:09 AM
sir, i cant download from the pando.. it says that the software already been deleted or something... please renew teh page.. thanks
regards,
ben
i guess one shouldnt buy refurb copiers in the 3rd world - one never knows what the counts will be - oddly enough as a tech i would never imagine resetting the main counter :cool:
blackcat4866
03-02-2008, 12:24 AM
Thanks Canuck.
Unethical. It's just unethical to reset counters. You deserve your counter related errors if you are trying to bilk the cutomer into thinking the machine is new, or only slightly used.
How would you like to buy a copier with 2.5 million copies, that the counter says 125K? I know that I would be PISSED!
JustManuals
03-02-2008, 03:30 PM
Well,its your own fault for giving these foreigners the information on how to reset the counters!
Somebody asks on their one and only post and then some moron comes along and posts it.:confused:
Paul@justmanuals.com
rajkumar
06-02-2008, 07:06 AM
please send me the solution thru email (push_vai@yahoo.com)
with regards
rajkumar
djbass
06-02-2008, 09:13 AM
I also can not think of a legitimate reason for resetting the counter, those that are most likely wish to commit fraud.
I don't think it would work with newer iR's anyway as they are designed to avoid exactly that situation. The counter is duplicated between the counter pcb and the main controller. If you swap just the counter pcb it copies the count info to the new board, and vice verse if you swap the main board it gets copied from the counter pcb, if you swap both boards you get an error.
mitsubee
06-27-2008, 08:25 AM
Hello , resetting the counter can be done d , using the SST software and a special file that we re-write the counter board data.That special file is also a *.upd file that run compatible on SST.Just throw into the machine it`s under SYSTEM v43.01.
zkafs
06-27-2008, 10:05 AM
pls forget it
_SuabE_
06-27-2008, 10:41 AM
If you want to RESET Counter for Canon IR Series, Let me Reset for you :D
jacking with the counter is a good way to nuke the whole machine. dont do it unless you want to use it as a doner
ben-copier
06-28-2008, 08:27 PM
If you're to purchase from other sources, they'll be no updates for future upgrades In order for updates & future updates, please visit www.bootrom.biz (http://www.bootrom.biz/)
We have received many of request updates that they’re bought from other sources. But we've denied because they just hit & run. Get your money and just disappeared.
Just to remind any of their customers, please be aware. You never get any updates from them after you've transfer your money.
haydar64
03-07-2009, 02:24 PM
Helle, can u share again this file?
Thanks a lot.
HAYDAR64
thenappan
03-08-2009, 01:09 PM
hi
can u tell me how to reset and where i can get the software
thanks in advance
So far as I'm aware there are only chip resetters availabe for Oce,KM and Ricoh.
There are no resetters available for Canon boxes to the best of my knowledge.
mtech
04-08-2009, 12:00 AM
Resetting counters? Where are your ethics? The biggest reason to RESET a counter is to deceive. You can always find a way to compensate for variances. Bad Karma. Nothing good will come of it.
mitsubee
04-08-2009, 05:00 AM
Bro Oze. for canon ir-series e-counter can be reset no need any chips..... file name 0000000.upd the is the file that u throw in using SST.that`s it....all counter will go Zero.
thenappan
04-08-2009, 12:37 PM
dear mitsubee
where can i get that *.upd file to download to the ir series machines
thanks
Momolio
04-17-2009, 10:30 AM
dear mitsubee
thanks
with SST
mitsubee
04-19-2009, 08:20 AM
The zero .upd file is not available for download bro.From my knowing the file was leaked.
thanks
tomsonmark
04-30-2009, 11:57 AM
we have all canon solution(reset counter ,upgrade machine speed,upgrade u send...............)
my email tomsonmark8@gmail.com
Hi,
Thanking You,
-Zombiee
is what somebody made a success of has to recover the file Ben-copier and can it send it to me
thank you
skynet
06-09-2009, 08:48 PM
If the customer knows their getting a second hand machine (for want of a better description, I will never be a salesman) whats the problem, they just want it to work. If a manufacturer provides a way of zero'ing the counters who is to say its unethical.
We all know brand new products have 'teething problems' and the users of these copiers get familiar with them, the manufactures also learn from their mistakes and introduce remedies in future versions. If we take the canon 22/28/35/4570 series for example, these all suffered from jamming in the right door which the newer 3045 family had fixed. So if we take a 2270 with little milage replace the durables and take the improved parts from the newer machines and fit them, we now have a machine that will to the best of our knowledge work well, cause the customer less problems and therefore less problems for our field service technicians.
pinkia
06-10-2009, 01:55 PM
Dear ,
Plz, send the informations on my email asok_c50@rediffmail.com
abdoubf
03-05-2011, 06:44 PM
i would like to reset the copy counter in ir 3045/3245/5570/5065
anothertech
03-05-2011, 08:10 PM
Yes, I bet you would. Good luck with that.
CT Copier Repair
03-05-2011, 11:54 PM
I have and can do this but
it is illegal
the asshole who i did this for I narced on so he got screwed
and I quit working for him
but at the time it was do this or feed my kids
I am a canon tech.
My question relies on the other side of story.
Is there any way to understand if the counter has been modified ?
I mean avoiding being a victim.
I am talking about ir6570 & iR105.
thnx
V-P
charm5496
04-15-2011, 06:16 PM
as far as I know there is nothing out there that can accomplish this without messing up the machine. I would think your machines would have an E355 error codes or something similar to that in the error history.
I am getting a used iR105 + Fin. with a meter below 500 K. Which seems a bit unusual. I am very suspicious about the meter on this machine.
Just wanted to know if there is a way of knowing before buying.
CT Copier Repair
04-15-2011, 07:45 PM
Yea
the condition of the machine
if it sounds too good to be true it is
I have seen a few 105's with low copy counts
as for how to tell you need to be able to understand the file system and some of the inf files
and if they have been edited properply then you cannot tell
Been there done that
they have been doing it overseas for about 6 years now
I know as I have seen them do it machines exported to Korea and such
watched them do it talked with them about it
they thought they were the only ones that could do it
i showed them how I did it they didn't believe that an American could figure it out
as we are not savvy enough
Enough about this topic
ITS ILLEGAL AND IMMORAL AND UNETHICAL
All the things I am not
Dshore
05-06-2011, 04:36 PM
I know it may seem wrong but resetting counters prior to rental is fine,makes it far easier to bill customer.....
If anyone wants to know how then contact me....only for rentals
ravi2bishnoi
05-14-2011, 12:33 PM
change counter & serial board in a new machine & ten replace & use in old machine ur counter change in new machine
rasya.ssd
03-19-2012, 10:39 AM
This eror Counter n serial incompatible
JustManuals
03-19-2012, 11:21 PM
3rd world.........
rasya.ssd
05-12-2012, 03:00 AM
yes please tell me how about to reset counter in IR 5570/5065.. Please contact me or send me to ian_boysahm@yahoo.co.id. Thanks..
jcontractor
05-12-2012, 03:50 AM
Hi,
Thanking You,
-Zombiee
The best way is buying a new "0" copies machine.
Total counter is important to get the proper maintenance for machine.
Well the machine is your boss property.
Is that helpful for a machine?
JustManuals
05-12-2012, 03:55 AM
If we told you, we'd have to kill you too.
