View Full Version : Konica 7022 f35-4 error
HUNG99
06-15-2007, 03:15 AM
Urgent! Pls help me with Konica 7022 f35-4 error code! Thank a lot!!!!!:confused: It does not work for a long time !!!
bushy
06-15-2007, 05:24 AM
call a tech!!!!
you have a heater problem that needs to be safety checked
HUNG99
06-15-2007, 05:43 AM
I have called a tech, but he does not know much about 7022
Pls show me how to settle it ! Very urgent!
bushy
06-19-2007, 05:13 AM
go to 25 mode select software switch
go to address 3-1 turn switch to 0
turn m/c off/on
a tech will understand these instructions even if you dont
call a tech!!!!
ebm
06-19-2007, 07:50 PM
If you are not going to call in a qualified service tech the easiest thing would be to replace the fuser unit. If it is not the fuser unit then the problem would most likely be out of your hands to resolve without qualified technical service. The image control and printer control boards may be the next likely suspects, which would require replacement and firmware reprogramming.
HUNG99
06-20-2007, 08:58 AM
Thank you for your help! I 've solved the problem.
