View Full Version : konica1212
cliffhangers
01-20-2011, 10:59 AM
it have problem with corona wire the corona wire is there bet it copy blank please i need your help on this konica1212 thanks in advance.
crismoncy
01-20-2011, 01:08 PM
try to check the charging corona unit and transfer/separation unit maybe one of that wires worn out.so it will cause blank copy.
ddude
01-21-2011, 04:35 AM
Can't remember, but if there is a cleaning pad assy, it may not be seated in home position, causing the short-if present, run the cleaner back-and-forth.
mrwho
01-21-2011, 09:39 AM
Didn't those machines have a recurring problem where a gear on the back of the machine would get stuck (when opening the machine) and wouldn't give movement to the drum unit, causing blank copies?
mrwho
01-21-2011, 09:44 AM
More tips:
DESCRIPTION: Blank copies.
PROBABLE CAUSES:
1. CN32 at the HV unit is disconnected. Reconnect CN32.
2. Currents cannot be adjusted. No output from the high voltage unit. Replace the HV unit
PROBABLE CAUSES:
1. IP2 on main control board open, preventing 24V DC from reaching HV unit.
2. Check the Transfer/Separation contact springs located at the rear of the T/S corona Unit. Expand the contacting springs to ensure sufficient upward pressure.
