View Full Version : Error Code Minolta Di550 C-OF33 Error Code?
nizar642
01-20-2011, 04:04 PM
Hi,
I own a konica minolta Di550 and today an error occured saying C-OF33. The machine "eats" the paper and stops leaving half of the paper outside and the other half inside.
Appreciate any help
Chip Resets SA
01-20-2011, 05:30 PM
Usually the developer is shot and needs to be replaced. The developer is basically your toner carrier and has a certain lifespan. You should have the developer replaced by a Konica Minolta technician.
i agree with you , change the developer
fixthecopier
01-21-2011, 10:39 AM
If the developer has run its life, it probably needs a drum also.
beatbrother
04-05-2011, 03:00 PM
Fixthecopier is correct, also do not forget the drum blade
