View Full Version : Error Code LDAP lookups - "Failed to resolve name in DNS server" <- C352s
DeLF
01-31-2011, 05:13 AM
Hi all,
We have several C352 printers and we need to authenticate them against AD. I have spent a long time testing and configuring LDAP to do lookups and each and everytime i click the "Test Connection" button I get the error Failed to resolve name in DNS server.
I know my DNS setting are correct and both forward and reverse maps resolve perfectly. (The printer has perfect LAN connectivity).
I am suspecting a firmware bug ?
Can anyone suggest how to debug this further ? (konica tools ?)
This is the current firmware dump (i have no clue what the latest is?)
MFP Controller BOOT Program
9J06-1E00-G00-01-000(00)
MFP Controller SubSet Program
9J06-1F00-G00-02-000(00)
MFP Controller
9J06-0100-G00-I8-000(00)
Operation PANEL Message Data
9J06-8100-G00-I2-008
FAX Board Controller1
 FAX Board Controller2
 IR
9J06-0023-G00-10-000
PRT
9J06-0050-G00-20-000
LPH
 ADF
9J07-0024-G00-06-000
Finisher
9J08-0071-G00-06-000
System Controller
9J06-1000-G00-I8-000(00)
Printer Controller
9J06-3000-G00-43-000(00)
Printer Controller-Font
9J06-3F00-G00-14-000(00)
Printer Controller-Demo Page
4037-3E00-G00-00-000
MIO
9J06-5000-G00-63-000(00)
PSWC
9J06-5100-G00-34-000(00)
MIB IF
9J06-5200-G00-20-000(00)
IPP IF
9J06-5300-G00-03-000(00)
External Controller IF
 TCP/Socket
9J06-6300-G00-00-000(00)
Open API
9J06-7000-G00-86-000(00)
Operation PANEL
9J06-8000-G00-E0-000(00)
CSRC
9J06-8300-G00-02-000(00)
PIC
9J06-8200-G00-07-000
-Alex
pepper38_cnd
01-31-2011, 01:01 PM
Maybe this will help?
DeLF
01-31-2011, 01:26 PM
Thanks, but i have tried all possible configuration possibilities and I still get the error Failed to resolve name in DNS server when clicking "check connection".
Besides resorting to a packet trace are there any other tools you can recommend to get more debug output than "Failed to resolve name in DNS server." on konica printers ?
-Alex
JR2ALTA
01-31-2011, 03:09 PM
You could try to dump the DNS cache, from what I understand it's harmless and solves a lot of problems.
But Google it or talk to an IT professional first...
Spidula
01-31-2011, 05:25 PM
Latest F/W is K0 for the 352s But I had an LDAP prob with a machine with K0 F/W on. I.T sorted it eventually, but don't know what the fix was!
RRodgers
01-31-2011, 07:40 PM
Last time I had a problem with LDAP it turned out to be the time on the copier was off by more than an hour. CHECK the TIME on the copier.
BlueBlazer
01-31-2011, 10:47 PM
Find out what your AD's server IP is and try connecting directly if flushing your DNS cache doesn't resolve the problem. Also double check that the IT department didn't do anything screwy with their AD server like set SSL or something.
Stirton.M
02-01-2011, 02:30 AM
I agree, use an IP address instead.
LDAP is for the most part fairly straight forward to configure on these machines. Of the few customers who use it, I have not seen a problem like this.
And of course, updating the firmware may help some.
also, the following may provide some insight...
Description
Cannot perform single or multiple character searches in Microsoft® Windows 2003 Active Directory domain.
Solution
CAUSE: These engine series ‘Use Referral’ function are not compatible with LDAP \Domain Controller at Domain Functional level of Microsoft® Windows
2003.
SOLUTION: Refer attached document to disable 'Use Referral' function.
Description
How to setup LDAP on a C250.
Solution
To set up LDAP on a C250, perform the following:
1. Click on Utility/Counter.
2. Administrator Setting [12345678], Click OK.
3. Click on Network Setting.
4. Click on LDAP Setting.
5. Enable LDAP to ON and Click OK.
6. Click on Setting Up LDAP.
7. Select an Empty Selection BOX.
8. Enter LDAP Server Name.
9. Click on FWD &gt;.
10. Enter Server IP Address. ie.- 11.11.0.2.
11. Enter Search Base. ie.- dc=kmbs, dc=local .
12. Click on FWD &gt;.
13. Enable SSL to OFF, Port No. = 389, Port Number (SSL) = 636.
14. Click on FWD &gt;.
15. Select Authentication Method ie.- SIMPLE.
16. Click on FWD &gt;.
17. Select Server Authentication Method - Use Set Value.
18. Use Referral set to OFF.
19. Click on FWD &gt;.
20. Enter Login Name ie.- user1.
21. Enter Password ie.- 1234.
22. Enter Domain Name. ie.- kmbs.local.
23. Click on OK, Close, Close, Close, Close, Close.
24. Reboot copier.
Troubleshooting Tips:
1. Ping the Server using the Copier.
2. Setup the LDAP information given using your Laptop with the Following Software's - PageScope Address Utility or Softerra* LDAP Browser 2.6.
Notes:
a. As reference, see the function settings document and How to setup LDAP Setting on MFP Device .
Description
LDAP does not function after upgrading firmware.
Solution
CAUSE: Corrupt firmware.
SOLUTION: Download the latest firmware version and re-flash the machine.
