View Full Version : konica1120
cliffhangers
01-31-2011, 03:52 PM
good day and thanks for being so kind.i just fine out that the toner motor is not feeding the developer unit.what can i do to solve this problem so that the toner motor will send toner in the developer unit.i really need help on this.thanks in advance.
remati
01-31-2011, 10:14 PM
...in tec mode "4" "7" you see de motor ,run?...the gear and the drive shaft, run..?
-If the answer is yes...change the developer and make the developer adjust..
