View Full Version : Canon NP6221 Black Copies
jamesw_80465
06-21-2007, 04:20 PM
I have a Canon NP6221 that is putting out black copies (Dark background but the image is still visible). I have checked the main charge wire and it appears to be good. Any help would be appreciated.
Herrmann
06-29-2007, 05:36 PM
Ok, lets do it from the scratch:
Did you clean all mirrors, including mirror nr6 ?
does the scanner lamp fire up correctly?
are the spacer rollers of the development unit worn?
make sure, that there is genuine Canon Toner used!
Hope, this helps
Greetings from Germany
Herrmann
jamesw_80465
06-29-2007, 05:54 PM
Thank you for your information. I found out that there is a density slider inside the front cover and someone had run it all the way to dark.
