View Full Version : Help! Samsung Scx 4216f
COPIER SPECIALISTS
06-24-2007, 03:08 PM
I have a Samsung SCX 4216f. The MFP has simply gone "dead". When the power is switched on after the copier has been "off" for a day or two, the toner light briefly flashes on for a second - then nothing again. My Technician says some problem with the power supply, but as it is build in to a circuit board he needs a SM to trace the faulty component. Any advise please?:confused:
10871087
06-24-2007, 05:12 PM
Are you located in the United States?
COPIER SPECIALISTS
06-24-2007, 05:24 PM
No, South Africa - relevance?
10871087
06-24-2007, 06:57 PM
Here in the US, we would normally only troubleshoot down the the board level so it was unusual to here someone going down the the component. I don't have a manual for you should be able to find something if you look around.
Good Luck
Tonerbomb
06-25-2007, 04:53 AM
it's relevant if you are on 208 vac instead of 110 vac for power. Samsung makes both versions in many models, and they typically don't repair to component level they replace assemblies.
gadgetman
03-02-2010, 07:44 AM
Folks,
I have the same issue as the original poster. When I power the samsung up I get a glimmer of light as described by the original poster but then nothing.
I have opened up the power supply board, and cannot see any obvious failed components, apatt from 2 capacitors have have bellowed on the top.
Anybody able to advise? Also can the original poster offer any advice how he/she sorted the problem?
